Husqvarna Opal Plus - condenser problem?
Danny
Re: Husqvarna Opal Plus - condenser problem?
Inlägg av Danny »
If you look at the board you see the position(K1,Q3) printed on.
CPU'n are surface mont on the other side.
The triac should be this one: http://www.datasheetcatalog.org/datashe ... s/7471.pdf
Danny
Inlägg av Danny »
You should start with checking the powersupply.
Test over the caps C4,C6 and C8.
C4 = 9,1V
C6 = 4,9V
C8 = 10,5V
When you start the refridgerator, do you hear a click sound after 1 minute from the powerboard?
Does the buzzer sound the alarm?
NOTICE that the relay dosen't activates before 1min after you pushed on/off and you have "-" in the display.
Also notice that all the voltage on the powerboard is dangerous because of the non isolated powersupply.
CPU'n: http://www.datasheetcatalog.org/datashe ... 6l4p3y.pdf
Danny
Inlägg av Danny »
Did you give up?
Ian-Oslo
Inlägg av Ian-Oslo »
Hi Danny. No, I didn't give up. My hard-drive on my laptop did however. So at the moment, it is not the top priority on my list of things-that-must-get-done. Hope you can understand. And now the belt on our Italian washing machine has decided it's pooped out as well. So it's off to Elkjop to get that fixed and keep the wife happy. We already replaced the kjoleskap, so the Husqvarna is just waiting for me patiently. Will keep in touch soon. Ciao, Ian
