Strömförsörjning till ett micro ATX moderkort (båtdator)
v-g
Inlägg av v-g »
lgrfbs:Funkar här men verkar vara en synnerligen ostabil sida.
Kontentan är dock "YOU NEED TO PROVIDE REGULATED 12V TO THE PW200M TO PREVENT DAMAGING THE COMPONENTS POWERED BY IT, BECAUSE THE PW200M DOES NOT REGULATE THE 12V RAIL." som det står med STORA bokstäver på sida 2.
Synnerligen intressant var denna fråga som besvarades av tillverkaren:
Just for the sake of amusement, here's an email I sent to the PW-200 manufacturers months ago:
Quote:
How exactly do you justify rating the PW200 supplies at 200W if you
don't even regulate the 12v line? saying that almost 3/4 of the power
rating of your supply is coming from the unregulated input that is
simply switched, is rather misleading. I assume that the 12A rating
on the 12v line is only due to the switching transistor? in which
case, you could drop in a transistor with higher current rating and
then rate the thing at 300W or more.
so basically you have a 60-watt supply with a 12v/12A switch... and
personally I've never heard anyone include what is essentially nothing
more than a power switch in the power rating of their computer... for
instance, my shutdown controller has a relay that can switch around 10
amps at 12 volts, to power various peripherals... but I wouldn't call
the SDC a 120 watt power supply...
and here is their reply:
Quote:
That's true, there is a little bit of marketing here, but anybody that makes
12V DC-DC converters can claim that.
This is a 'switching" power supply, it just happens that the 12V rail is
permanently switched.
There is no regulation but there is UVP and OVP protection.
Mindmapper
Inlägg av Mindmapper »
Vilken svinig marknadsföringsavdelning!
Det visar hur viktigt det är att läsa databladen och reagera på konstigheter.
M2 ATX verkar just, men driver inte så mycket mer än hdd, cpu och mb.
Tar du ett till M2 ATX till 12V skärm har du några watt över till annat. Eller en något mindre psu till skärmen. Titta på vad skärmens behov är.
Eller väljer du någon annan lösning för skärmen?
netrunner
Inlägg av netrunner »
Jo, det var det man kunde gissa när man lästa det som inte stod i det finstilta. 8)
Här har du en skärm för bara 1200kr ink frakt. Den tar bara 640x480 tyvärr (det är ganska dålig, på gränsen för vad man kan stå ut med) - tittar man på andra som är dyrare så har dom samma problem, så det hjälper inte att bara kasta på mer pengar.
http://cgi.ebay.co.uk/8-TFT-LCD-AV-TV-V ... dZViewItem
Celeron II var sista steget i socket 370, det var samlad erfarenhet av 7 generationer i den, allt var så optimerat som det gick.
Såldes som en budgetprocessor då dom kunder med mer pengar kund köpa en P3 (som var samma men med 133MHz FSB istället för 100MHz och med mer L2-minne). Skillanden var tillslut inte mer än ca 1,5-4% så det var svårt att motivera mer än det dubbla priset för P3:an.
En annan fördel med Celeron II var att den var multipellåst. Du kunde med en adapter montera den i P2-datorer och gå från 266MHz -> 733MHz / 400MHz -> 1000MHz i ett steg.
Det finns även en Celeron II "tulatin" på 1100MHz-1400MHz som är ett steg bättre men mycket svår att hitta moderkort till. Det finns lite olika konverters men jag har bara testa en som var omotiverat dyr.
wirre
Inlägg av wirre »
Kontaktade företaget som säljer i Sverige och informerade om problemet, jag skickar tillbaks kortet och köper M2-ATX istället, löser alla problem hoppas jag.
Att strömmata skärmen (12v) kanske den orkar med, gör den inte det bygger jag en egen 12v spänningsstab bara till att driva skärmen.
När jag får igång grejerna ska jag mäta lite drivströmmar vid normaldrift och underklockning (p4 2,0Ghz)
Jag återkommer
wirre
netrunner
Underklockning låter spännande undra vad du kommer att få för värden där.
Effektiviteten är inte alltid den bästa, många av dom jag har hitta ger bara 75-80% när man kanske vill ha 90%+
Minus
Inlägg av Minus »
finns intressanta artiklar på denna sida
är väl matseng som är pappa till hemsidan
http://aoe.nerdlabs.org/
följande beskrivningar kan ju vara läs o se värda !
Nätaggregat i bilen för MP3 CDspelaren OSCAR
Fordonsadapter for Notebook PC, 19 volt från ett bilbatteri
