Tips på billig WIFI-modul (ESP8266)
adent
Re: Tips på billig WIFI-modul (ESP8266)
Inlägg av adent »
Hur ser uC-koden ut?
MVH: Mikael
lond
Inlägg av lond »
Har den inte på samma dator....
Kommer kanske att lösa så att min pH-sensor pratar direkt i LUA, men kanske inte..
Har dock kommit fram till att jag kan skippa t2-variablen (en liten tankevurpa).
/// Marcus
lond
Inlägg av lond »
Koden i µP som pratar med ESP8266:
'*  Name    : pH-sens_lua.BAS                                   *
'*  Author  : Marcus Xxxxxxxxx                                  *
'*  Notice  : Copyright (c) 2015 Marcus Xxxxxxxxxxx               *
'*          : All Rights Reserved                               *
'*  Date    : 2015-03-01                                        *
'*  Version : 0.0.0.5                                           *
'*  Notes   :                                                   *
'µP
;**** Added by Fuse Configurator ****
; Use the Fuse Configurator plug-in to change these settings
Device = 16F690
Config FOSC_INTRCIO, WDTE_OFF, PWRTE_OFF, MCLRE_OFF, CP_OFF, CPD_OFF, BOREN_OFF, IESO_OFF, FCMEN_OFF
;**** End of Fuse Configurator Settings ****
        Declare Reminders = OFF
'µP speed
        Xtal = 8
'Bootloader
        Declare Bootloader = 0
'ALL_DIGITAL
        Declare All_Digital = TRUE
' -----[ I/O Definitions ]-------------------------------------------------
        Symbol LED = PORTC.2
        Symbol IO1 = PORTC.6
        Symbol LEDr = PORTA.4
        Symbol LEDg = PORTA.5
        'Hw RX/TX
        Declare Hserial_Baud = 9600     ' Set baud rate to 9600
        Declare Hserial_RCSTA = %10010000 ' Enable serial port and continuous receive
        Declare Hserial_TXSTA = %00100000 ' Enable transmit and asynchronous mode
        Declare Hserial_Clear = On      ' Clear the buffer before receiving
        'Sw RX/TX
        Declare Rsin_Pin = PORTC.1
        Declare Rsout_Pin = PORTC.0
        Declare Serial_Baud = 9600
        Declare Rsin_Mode = 0
        Declare Rsout_Mode = 0
        Declare Rsin_Timeout = 10000
' -----[ Constants ]-------------------------------------------------------
        Dim CR As $0D                       ' Carriage Return
        Dim LF As $0A                       ' Line Feed
        Dim DQ As $22                       ' Double Quote "
' -----[ Variables ]-------------------------------------------------------
        Dim I2cData As Byte                 ' Data on i2c bus
        Dim Loop As Byte                    ' Loopcounter
        Dim SerData As Word                 ' Serial information
        Dim PH[20] As Byte
        Dim Cal As Byte
' -----[ Initialization ]--------------------------------------------------
OSCCON = %01110000      ' 8MHz
Input IO1
Low LEDg
Low LEDr
High LED
RSOut "E", CR
DelayMS 2000
RSOut "E", CR
DelayMS 1000
RSOut "15.00", CR
'DelayMS 60000
DelayMS 4000
GoSub resetWIFI
' -----[ Program Code ]----------------------------------------------------
Main:
Low LED
RSOut "R", CR
Loop = 0
While 1 = 1
    I2cData = RSIn, {TimeOut}
    If I2cData = CR Then Break
    If Loop = 19 Then Break
    PH[Loop] = I2cData
    Inc Loop
Wend
PH[Loop] = 0
If PH[0] > "9" Or PH[0] < "0" Then GoTo TimeOut
DelayMS 2000
GoSub postDATAts
DelayMS 1000
Low LEDg
For Loop = 1 To 240
    DelayMS 30000
    If IO1 = 1 Then
        High LEDr
        GoSub UnButton
        GoSub Calibration
    EndIf
Next
GoTo Main
End
' -----[ Subroutines ]-----------------------------------------------------
Calibration:
DelayMS 2000
RSOut "C", CR
DelayMS 1000
DelayMS 2000
Repeat Until IO1 = 1
GoSub UnButton
DelayMS 60000
DelayMS 60000
High LEDg
RSOut "S", CR
DelayMS 1000
GoSub UnButton
Low LEDg
DelayMS 60000
DelayMS 60000
High LEDg
RSOut "F", CR
DelayMS 1000
GoSub UnButton
Low LEDg
DelayMS 60000
DelayMS 60000
High LEDg
RSOut "T", CR
DelayMS 1000
RSOut "E", CR
DelayMS 1000
GoSub UnButton
Low LEDr
Low LEDg
Return
resetWIFI:
HSerOut ["node.restart()", CR, LF]
HSerIn 15000, TimeOut, [Wait("Connected to WIFI!")]
High LEDg
DelayMS 200
Low LEDg
Return
postDATAts:
HSerOut ["token=", DQ, CStr API, DQ, CR, LF]
HSerIn 5000, TimeOut, [Wait("> ")]
HSerOut ["f1=1", CR, LF]
Loop = 0
HSerOut ["t1="]
While 1 = 1
    If PH[Loop] = 0 Then Break
    HSerOut [PH[Loop]]
    Inc Loop
Wend
HSerOut [CR, LF]
HSerOut ["dofile(", DQ, "Thingspeak2.lua", DQ, ")", CR, LF]
HSerIn 15000, TimeOut, [Wait("Connected", CR, LF), Dec SerData]
If SerData = 0 Then
    DelayMS 5000
    GoSub resetWIFI
    GoTo Main
EndIf
High LEDg
Return
TimeOut:
High LED
GoSub resetWIFI
DelayMS 2000
GoTo Main
UnButton:
Repeat Until IO1 = 0
DelayMS 300
Return
End
' -----[ CData ]-----------------------------------------------------------
API: CData "--token--", 0
/// Marcus
edit: Lite censur :vissla:
ronnylov
Inlägg av ronnylov »
Ser att du heter samma efternamn som jag Marcus!
Knappast släkt dock (jag kommer från Gästrikland från början).
Hur som helst är det roligt att se hur du använder din modul.
Verkar ju ganska smidigt att köra LUA på modulen.
