Raspberry Pi
| Model A | Model B | |
GPIO
| left | |||
| bottom | top | ||
| P1-01 | P1-02 | ||
| 1 | 3,3V | 5V | |
| 2 | GPIO 0 (SDA) | 5V | |
| 3 | GPIO 1 (SCL) | GND | |
| 5 | GND | GPIO 15 (RxD) | |
| 8 | GPIO 22 | GPIO 23 | |
| 9 | 3,3V | GPIO 24 | |
| 13 | GND | GPIO 7 (CE1) | |
| P1-25 | P1-26 | ||
| bottom | top | ||
| right | |||
3,3V klarar max 50 mA.
| Rev 1 | Rev 2 |
| GPIO 0 | GPIO 2 |
| GPIO 1 | GPIO 3 |
| GPIO 21 | GPIO 27 |
Priser
| Model A 256 MB | webhallen.com | 239 SEK | 2013-03-09 |
| Model B 512 MB | webhallen.com | 325 SEK | 2013-03-09 |
| Model 512 MB | inet.se | 349 SEK | 2013-03-09 |
(svenska priser inklusive moms)
- enwp: Raspberry Pi
