Tekniska data
Model A |
Model B
| SoC:
Broadcom BCM2835 (CPU, GPU, DSP, SDRAM, 1x USB port)
| CPU:
700 MHz ARM1176JZF-S core (ARM11 familjen)
| GPU:
Broadcom VideoCore IV
| Minne:
256 MB (delad med GPU:n) |
512 MB (shared with GPU) per 2012-10-15
| USB 2.0 portar:
1x port |
2x port
| Nätverk:
Inget |
10/100 Ethernet (8P8C)
| Videoutgång:
Composite RCA, HDMI, LCD Paneler via DSI
| Ljudutgång:
3,5 mm jack, HDMI
| Lagring:
SD / MMC / SDIO card slot
| I/O:
8 × GPIO, UART, I²C bus, SPI bus med två "chip selects", I²S
| Effekt:
300 mA (1,5 W) |
700 mA (3,5 W)
| Elmatning:
5 volt via MicroUSB eller GPIO header
| Mått:
85,60 × 53,98 mm
GPIO
P1 revision 1
left
bottom |
top
P1-01 |
P1-02
| 1 |
3,3V |
5V
| 2 |
GPIO 0 (SDA) |
5V
| 3 |
GPIO 1 (SCL) |
GND
| 4 |
GPIO 4 (GPCLK0) |
GPIO 14 (TxD)
| 5 |
GND |
GPIO 15 (RxD)
| 6 |
GPIO 17 |
GPIO 18 (PCM_CLK)
| 7 |
GPIO 21 (PCM_DOUT) |
GND
| 8 |
GPIO 22 |
GPIO 23
| 9 |
3,3V |
GPIO 24
| 10 |
GPIO 10 (MOSI) |
GND
| 11 |
GPIO 9 (MISO) |
GPIO 25
| 12 |
GPIO 11 (SCLK) |
GPIO 8 (CE0)
| 13 |
GND |
GPIO 7 (CE1)
P1-25 |
P1-26
bottom |
top
right
3,3V klarar max 50 mA.
Revisionsförändringar
| Rev 1 |
Rev 2
| GPIO 0 |
GPIO 2
| GPIO 1 |
GPIO 3
| GPIO 21 |
GPIO 27
Priser
| Produkt |
Leverantör |
Pris |
Datum
| Model A 256 MB |
m.nu |
259 SEK |
2013-02-09
| Model A 256 MB |
m.nu |
195 SEK |
2013-07-15
| Model B 512 MB |
m.nu |
345 SEK |
2013-02-09
| Model A 256 MB |
farnell.com |
25 USD |
2013-02-09
| Model B 512 MB |
farnell.com |
35 USD |
2013-02-09
| Model 512 MB |
netonnet.se |
335 SEK |
2013-02-26
| Model A 256 MB |
webhallen.com |
239 SEK |
2013-03-09
| Model B 512 MB |
webhallen.com |
325 SEK |
2013-03-09
| Model 512 MB |
inet.se |
349 SEK |
2013-03-09
| Model B 512 MB v.2 |
kjell.com |
349 SEK |
2013-07-11
| Model B 512 MB v2 |
invector.se |
305 SEK |
2013-07-12
(svenska priser inklusive moms)
