Raspberry Pi
| Model A | Model B | |
GPIO
| left | |||
| bottom | top | ||
| P1-01 | P1-02 | ||
| 1 | 3,3V | 5V | |
| 2 | GPIO 0 (SDA) | 5V | |
| 3 | GPIO 1 (SCL) | GND | |
| 5 | GND | GPIO 15 (RxD) | |
| 8 | GPIO 22 | GPIO 23 | |
| 9 | 3,3V | GPIO 24 | |
| 13 | GND | GPIO 7 (CE1) | |
| P1-25 | P1-26 | ||
| bottom | top | ||
| right | |||
Priser
| Model B? 512 MB | netonnet.se | 379 SEK | 2013-02-16 |
- enwp: Raspberry Pi
