Raspberry Pi
Model A | Model B | |
Mått: | 85,60 × 53,98 mm |
GPIO
left | |||
bottom | top | ||
P1-01 | P1-02 | ||
1 | 3,3V | 5V | |
2 | GPIO 0 (SDA) | 5V | |
3 | GPIO 1 (SCL) | GND | |
5 | GND | GPIO 15 (RxD) | |
8 | GPIO 22 | GPIO 23 | |
9 | 3,3V | GPIO 24 | |
10 | GPIO 10 (MOSI) | GND | |
13 | GND | GPIO 7 (CE1) | |
P1-25 | P1-26 | ||
bottom | top | ||
right |
Priser
Model B? 512 MB | netonnet.se | 379 SEK | 2013-02-16 |
- enwp: Raspberry Pi
