Ytmonterade
Passiva
Dioder
"Fyrkantiga"
  * SMA - 2,7x5 mm.
  * SMC - 5,9x7,8 mm.
"Runda"
  * MELF - 2,7x5,2.
"SOT lookalike"
Transistorer
 SOT23
 SOT143
Dual in-line
Quad in-line
QFP - Quad Flat Pack
QFN - Quad Flat pack No-leads
Grid arrays
BGA - Ball Grid Array
LGA - Land Grid Array
