Ytmonterade
Passiva
Dioder
  * SOD106A - 2,5x5,5 mm kapsel, tämligen vanlig i små switchomvandlare.
  * SOD110 - 2,1x1,4 mm kapsel
Transistorer
 SOT23
 SOT143
Dual in-line
Quad in-line
QFP - Quad Flat Pack
QFN - Quad Flat pack No-leads
Grid arrays
BGA - Ball Grid Array
LGA - Land Grid Array
