Varför blir det konflikt I MPLAB
Postat: 30 januari 2025, 13:27:59
Försöker konfigurera pinnarna i MPlab MCC. Man jag får en konflikt på alla pinner jag satt som analoga ingångar.
Vad är det som jag missförstår.
Försöker även toggla en pinne för att se om det lever men det verkar stå helt still. Vad har jag missat?
MAIN
PIN MANAGER FILE
CONBITS
MAIN
#include <xc.h>
#include "mcc_generated_files/mcc.h"
void main(void) {
while(1){
LATBbits.LATB1=1;
__delay_ms(100);
LATBbits.LATB1=0;
__delay_ms(100);
}PIN MANAGER FILE
#include "pin_manager.h"
void PIN_MANAGER_Initialize(void)
LATx registers
LATA = 0x00;
LATB = 0x00;
LATC = 0x00;
TRISx registers
TRISA = 0x7E;
TRISB = 0x41;
TRISC = 0x81;
ANSELx registers
ANSELC = 0x00;
ANSELB = 0x80;
ANSELA = 0x46;
WPUx registers
WPUE = 0x00;
WPUB = 0x00;
WPUA = 0x00;
WPUC = 0x00;
RxyI2C registers
RB1I2C = 0x00;
RB2I2C = 0x00;
RC3I2C = 0x00;
RC4I2C = 0x00;
ODx registers
ODCONA = 0x00;
ODCONB = 0x00;
ODCONC = 0x00;
SLRCONx registers
SLRCONA = 0xFF;
SLRCONB = 0xFF;
SLRCONC = 0xFF;
INLVLx registers
INLVLA = 0xFF;
INLVLB = 0xFF;
INLVLC = 0xFF;
INLVLE = 0x08;
// Configuration bits: selected in the GUI
// CONFIG1L
#pragma config FEXTOSC = OFF // External Oscillator Selection->Oscillator not enabled
#pragma config RSTOSC = HFINTOSC_1MHZ // Reset Oscillator Selection->HFINTOSC with HFFRQ = 4 MHz and CDIV = 4:1
// CONFIG1H
#pragma config CLKOUTEN = OFF // Clock out Enable bit->CLKOUT function is disabled
#pragma config PR1WAY = ON // PRLOCKED One-Way Set Enable bit->PRLOCK bit can be cleared and set only once
#pragma config CSWEN = ON // Clock Switch Enable bit->Writing to NOSC and NDIV is allowed
#pragma config FCMEN = OFF // Fail-Safe Clock Monitor Enable bit->Fail-Safe Clock Monitor disabled
// CONFIG2L
#pragma config MCLRE = EXTMCLR // MCLR Enable bit->If LVP = 0, MCLR pin is MCLR; If LVP = 1, RE3 pin function is MCLR
#pragma config PWRTS = PWRT_OFF // Power-up timer selection bits->PWRT is disabled
#pragma config MVECEN = OFF // Multi-vector enable bit->Interrupt contoller does not use vector table to prioritze interrupts
#pragma config IVT1WAY = ON // IVTLOCK bit One-way set enable bit->IVTLOCK bit can be cleared and set only once
#pragma config LPBOREN = OFF // Low Power BOR Enable bit->ULPBOR disabled
#pragma config BOREN = SBORDIS // Brown-out Reset Enable bits->Brown-out Reset enabled , SBOREN bit is ignored
// CONFIG2H
#pragma config BORV = VBOR_2P45 // Brown-out Reset Voltage Selection bits->Brown-out Reset Voltage (VBOR) set to 2.45V
#pragma config ZCD = OFF // ZCD Disable bit->ZCD disabled. ZCD can be enabled by setting the ZCDSEN bit of ZCDCON
#pragma config PPS1WAY = ON // PPSLOCK bit One-Way Set Enable bit->PPSLOCK bit can be cleared and set only once; PPS registers remain locked after one clear/set cycle
#pragma config STVREN = ON // Stack Full/Underflow Reset Enable bit->Stack full/underflow will cause Reset
#pragma config DEBUG = OFF // Debugger Enable bit->Background debugger disabled
#pragma config XINST = OFF // Extended Instruction Set Enable bit->Extended Instruction Set and Indexed Addressing Mode disabled
// CONFIG3L
#pragma config WDTCPS = WDTCPS_31 // WDT Period selection bits->Divider ratio 1:65536; software control of WDTPS
#pragma config WDTE = OFF // WDT operating mode->WDT Disabled; SWDTEN is ignored
// CONFIG3H
#pragma config WDTCWS = WDTCWS_7 // WDT Window Select bits->window always open (100%); software control; keyed access not required
#pragma config WDTCCS = SC // WDT input clock selector->Software Control
// CONFIG4L
#pragma config BBSIZE = BBSIZE_512 // Boot Block Size selection bits->Boot Block size is 512 words
#pragma config BBEN = OFF // Boot Block enable bit->Boot block disabled
#pragma config SAFEN = OFF // Storage Area Flash enable bit->SAF disabled
#pragma config WRTAPP = OFF // Application Block write protection bit->Application Block not write protected
// CONFIG4H
#pragma config WRTB = OFF // Boot Block Write Protection bit->Boot Block not write-protected
#pragma config WRTC = OFF // Configuration Register Write Protection bit->Configuration registers not write-protected
#pragma config WRTD = OFF // Data EEPROM Write Protection bit->Data EEPROM not write-protected
#pragma config WRTSAF = OFF // SAF Write protection bit->SAF not Write Protected
#pragma config LVP = OFF // Low Voltage Programming Enable bit->HV on MCLR/VPP must be used for programming
// CONFIG5L
#pragma config CP = OFF // PFM and Data EEPROM Code Protection bit->PFM and Data EEPROM code protection disabled
