Re: Clever II garageportsmotor - schema?
Postat: 26 september 2020, 21:42:28
				Hej igen,
In the mean time I've found the solution myself, details can be found below.
Ingredients:
- 4 diodes ( removed them from some older HW)
- DC to DC stepdown convertor
- Sonoff SV
- Reed switch
- Case
You can get a 24V from the outer side of the light bulb and the - from the BATT output.
Since I wasn't 100% sure if it's DC, I've added a AC to DC converter using 4 diodes, so now we have 24V DC.
Now you can connect the output from the diodes to the input of the DC-DC stepdown convertor which is adjusted to 12V (this is just to be safe and don't kill the sonoff)
From the sonoff you have to remove 2 resistors to make the relay independent from the ESP chip (you can find the details if many videos or ithead wiki)
From here I'm sure you know the rest, but if you have questions, feel free to ask.
I'm attaching some pictures with the semi-final setup
Trevlig helg till alla!
/Alex
Ingredients:
- Sonoff SV
- Reed switch
- Case
/Alex
