Velleman K8200 3D-skrivare
Priser uppdaterade 2014-08-11
Allmän info
X-Y axis
Configuratin.h
Configuration_adv.h
Pinout på AUX
| Namn | Pin | Standard funktion |
| PC4 | 33 | LCD D4 |
| PH1 | 16 | Encoder |
| PH0 | 17 | Encoder |
| PA5 | 27 | LCD RS |
| PA7 | 29 | LCD ENABLE |
| PA1 | 23 | Encoder button |
| PA3 | 25 | SD SS |
| SCK | 52 | SD SCK |
| MISO | 50 | SD MISO |
| GND | GND | GND |
| 12V | Vin | 12V |
| 5V | 5V | 5V |
| PC2 | 35 | LCD D5 |
| PC0 | 37 | LCD D4 |
| PC6 | 31 | LCD D7 |
| MOSI | 51 | SD MOSI |
| SS | 53 | Ingen |
| RST | RST | Reset knapp |
