Mikrokontroller perferienheter
| Tillverkare | Chip | Funktion | Gränssnitt | Omdöme |
| Silicon Labs | CP2201 | |||
| Sekio | S-7600A | TCP/IP stack | PPP över RS-232 | |
| Lantronix | XPort | Ethernet device server | 5V asynkront | |
| Micrel | KSZ8842-8 | 2-Port Ethernet switch with Non-PCI Interface | 8-bit address | |
| Micrel | KSZ8863FLL | Integrated 10/100BASE-T/TX/FX 3-port switch | MII / RMII / Turbo MI | |
| Micrel | KSZ8873 | Integrated 3-port 10/100 Managed switch with PHYs | 2xMII / RMII | |
| ENC60J | ||||
| WIZnet | WIZ820io | 10/100 Base-T Ethernet | SPI | |
| Texas Instruments | TCA9554APWR | Low voltage 8-bit I²C and SMbus I/O expander with interrupt output and configuration registers | I²C | ELFA: 73-295-04 |
