Mikrokontroller perferienheter
Tillverkare | Chip | Funktion | Interface | Omdöme |
Davicom | DM9000 | Ethernet 10/100 | 8-bit parallell | Bra |
Micrel | KSZ8851 | Ethernet 10/100 | SPI + 8-bit parallell | Bra |
ASIX | AX88796C | Ethernet 10/100 | SPI | 88796B fungerar bra |
Microchip | ENC624 | Ethernet 10/100 | SPI + parallell | Okänd funktion |
Microchip | ENC 28J60 | Ethernet 10 | SPI | Tokfel! |
Realtek | RTL8029AS | Ethernet 10 | 8-bit parallell | |
Realtek | RTL8019 | Ethernet 10 | 16-bit parallell? | Tappar massa paket >45% last |
Crystal Semiconductor | CS8900A | Ethernet 10 | 8-bit parallell | |
Silicon Labs | CP2200 | Ethernet 10 | 8-bit parallell | |
Silicon Labs | CP2201 | |||
WIZnet Inc | W3150A | Ethernet 10/100 + TCP/IP | ||
WIZnet Inc | W5100 | Ethernet 10/100 + TCP/IP | SPI + 8-bit parallell | Chip select trasig |
WIZnet Inc | W5200 | Ethernet 10/100 + TCP/IP | SPI | |
Ipsil | IPµ8932 | Ethernet + TCP/IP + Http server | ||
Sekio | S-7600A | TCP/IP stack | PPP over RS-232 | |
XPort | ||||
KZX8842 | ||||
KSZ8863FLL | ||||
KSZ8873 | ||||
ENC60J | ||||
WIZ820io | ||||
Microchip | MCP23018 | 16-bit I/O expander with open-drain outputs | I²C (MCP23S18=SPI) | |
Texas Instruments | TCA9554APWR | Low voltage 8-bit I²C and SMbus I/O expander with interrupt output and configuration registers | I²C |
