Mönsterkortstillverkare
Version från den 10 december 2010 kl. 22.49 av Mrfrenzy (diskussion | bidrag)
| Företag | Leveranstid | Frakt | Minimiantal | Exempel 1 | Egenskaper | Antal | Totalpris | Exempel 2 | Egenskaper | Antal | Totalpris | Exempel 3 | Egenskaper | Antal | Totalpris | Exempel 4 | Egenskaper | Antal | Totalpris | Filformat | Lager | Material | Kort | <Tolerans | Isolerlager | Min linje | Min avst | Ytterkoppar | Innerkoppar | Borrhål | Fräshål | Tolerans diam | Tolerans plac | Min solder mask | Min mask avst | Via | Förtenning | Guldplätering | |
| BatchPCB | ? | ? | 10? | 122x129mm | 1.6mm FR4, 2 lager, 2 solder mask, 1 silk screen | 10 | 990:- | 122x129mm | 1.6mm FR4, 2 lager, 2 solder mask, 1 silk screen | 50 | 2550:- | 4 | |||||||||||||||||||||||||||
| Gold Phoenix | 9d / 6d / 5d / 4d | $10 / $45 / $60 / $100 | 1 | 650cm2 | 1.6mm FR4, 2 lager, 2 solder mask, 1 silk screen, 7 mil trace, 15 mil hål | 1 | $109.99 | 1000cm2 | 1.6mm FR4, 2 lager, 2 solder mask, 1 silk screen, 7 mil trace, 15 mil hål | 1 | $99.99 | Gerber, Protel | 1-4 | FR4 | 0.6-3mm | Isolerlager | 4mil | 4mil | 2-6oz | 12mil | JA | $50 | $10 | ||||||||||||||||
| Olimex | ? | ? | 10? | 122x129mm | 1.6mm FR4, 2 lager, 2 solder mask, 1 silk screen | 10 | 990:- | 122x129mm | 1.6mm FR4, 2 lager, 2 solder mask, 1 silk screen | 50 | 2550:- | 4 | |||||||||||||||||||||||||||
| Seeedstudio | 2-3w / 1w | $4.68 / $39.42 | 3 | 50x50mm | 0.8-1.6mm FR4, 2 lager, 2 solder mask, 2 silk screen | 10 | $20 | 100x100mm | 0.8-1.6mm FR4, 2 lager, 2 solder mask, 2 silk screen | 10 | $40 | Gerber | 1-2 | FR4 | 0.4-2.4mm | 10% | 0.075-5.00mm | 6mil | 6mil | 35 µm | 17-100µm | 0.3-6.35mm | 0.3-6.30mm | 0.08mm | 0.09mm | 0.1mm | 0.1mm | 0.25-0.60mm | Ja | Ja | |||||||||
| Silvtronics | ? | ? | 10? | 122x129mm | 1.6mm FR4, 2 lager, 2 solder mask, 1 silk screen | 10 | 990:- | 122x129mm | 1.6mm FR4, 2 lager, 2 solder mask, 1 silk screen | 50 | 2550:- | 4 | |||||||||||||||||||||||||||
| SwechTrading | ? | ? | 10? | 122x129mm | 1.6mm FR4, 2 lager, 2 solder mask, 1 silk screen | 10 | 990:- | 122x129mm | 1.6mm FR4, 2 lager, 2 solder mask, 1 silk screen | 50 | 2550:- | 4 |
