MediaWiki API help
This is an auto-generated MediaWiki API documentation page.
Documentation and examples: https://www.mediawiki.org/wiki/Special:MyLanguage/API:Main_page
prop=deletedrevisions (drv)
- Denna modul kräver läsrättigheter.
- Denna modul kan användas som en generator.
- Source: MediaWiki
- License: GPL-2.0-or-later
Hämta information om raderad sidversion.
May be used in several ways:
- Get deleted revisions for a set of pages, by setting titles or pageids. Ordered by title and timestamp.
- Get data about a set of deleted revisions by setting their IDs with revids. Ordered by revision ID.
- drvprop
Which properties to get for each revision:
- ids
- The ID of the revision.
- flags
- Revision flags (minor).
- timestamp
- The timestamp of the revision.
- user
- User that made the revision. If the user has been revision deleted, a userhidden property will be returned.
- userid
- User ID of the revision creator. If the user has been revision deleted, a userhidden property will be returned.
- size
- Length (bytes) of the revision.
- slotsize
- Length (bytes) of each revision slot.
- sha1
- SHA-1 (base 16) of the revision. If the content has been revision deleted, a sha1hidden property will be returned.
- slotsha1
- SHA-1 (base 16) of each revision slot. If the content has been revision deleted, a sha1hidden property will be returned.
- contentmodel
- Content model ID of each revision slot.
- comment
- Comment by the user for the revision. If the comment has been revision deleted, a commenthidden property will be returned.
- parsedcomment
- Parsed comment by the user for the revision. If the comment has been revision deleted, a commenthidden property will be returned.
- content
- Content of each revision slot. If the content has been revision deleted, a texthidden property will be returned.
- tags
- Tags for the revision.
- roles
- List content slot roles that exist in the revision.
- parsetree
- Föråldrad. Use action=expandtemplates or action=parse instead. The XML parse tree of revision content (requires content model
wikitext).
- Värden (separerade med | eller alternativ): comment, content, contentmodel, flags, ids, parsedcomment, roles, sha1, size, slotsha1, slotsize, tags, timestamp, user, userid, parsetree
- Default: ids|timestamp|flags|comment|user
- drvslots
Which revision slots to return data for, when slot-related properties are included in drvprops. If omitted, data from the main slot will be returned in a backwards-compatible format.
- Värden (separerade med | eller alternativ): main
- To specify all values, use *.
- drvlimit
Limit how many revisions will be returned.
- Type: integer or max
- The value must be between 1 and 500.
- drvexpandtemplates
- Föråldrad.
Use action=expandtemplates instead. Expand templates in revision content (requires drvprop=content).
- Type: boolean (details)
- drvgeneratexml
- Föråldrad.
Use action=expandtemplates or action=parse instead. Generate XML parse tree for revision content (requires drvprop=content).
- drvparse
- Föråldrad.
Use action=parse instead. Parse revision content (requires drvprop=content). For performance reasons, if this option is used, drvlimit is enforced to 1.
- drvsection
Only retrieve the content of this section number.
- drvdiffto
- Föråldrad.
Use action=compare instead. Revision ID to diff each revision to. Use prev, next and cur for the previous, next and current revision respectively.
- drvdifftotext
- Föråldrad.
Use action=compare instead. Text to diff each revision to. Only diffs a limited number of revisions. Overrides drvdiffto. If drvsection is set, only that section will be diffed against this text.
- drvdifftotextpst
- Föråldrad.
Use action=compare instead. Perform a pre-save transform on the text before diffing it. Only valid when used with drvdifftotext.
- drvcontentformat
- Föråldrad.
Serialization format used for drvdifftotext and expected for output of content.
- Ett av följande värden: application/json, application/octet-stream, application/unknown, application/x-binary, text/css, text/javascript, text/plain, text/unknown, text/x-wiki, unknown/unknown
- drvstart
The timestamp to start enumerating from. Ignored when processing a list of revision IDs.
- Type: timestamp (allowed formats)
- drvend
The timestamp to stop enumerating at. Ignored when processing a list of revision IDs.
- drvdir
In which direction to enumerate:
- newer
- List oldest first. Note: drvstart has to be before drvend.
- older
- List newest first (default). Note: drvstart has to be later than drvend.
- Ett av följande värden: newer, older
- Default: older
- drvtag
Only list revisions tagged with this tag.
- drvuser
Lista endast sidversioner av denna användare.
- Typ: användare, genom något av användarnamn, IP-adress, interwikinamn (t.ex. "prefix>Exempelnamn") och användar-ID (t.ex. "#12345")
- drvexcludeuser
Lista inte sidversioner av denna användare.
- drvcontinue
When more results are available, use this to continue.
- List the deleted revisions of the pages Main Page and Talk:Main Page, with content.
- api.php?action=query&prop=deletedrevisions&titles=Main%20Page|Talk:Main%20Page&drvslots=*&drvprop=user|comment|content [open in sandbox]
- List the information for deleted revision 123456.
- api.php?action=query&prop=deletedrevisions&revids=123456 [open in sandbox]
