Dags att slakta Pleo
Postat: 19 september 2017, 19:13:00
Jag har en Pleo som själva gummihuden verkar lösas upp på.
Nu har jag börjat att kolla hur den ser ut inuti. Ganska spännande obduktion förestår!
Här är lite data:
Features:
color camera can distinguish between colors and detect motion
binaural microphones for stereo sound detection
IR pair to communicate with other Camarasauruses
IR interrupter to determine when something is placed in his mouth
eight touch sensors on his chin, shoulder, legs, back and head
realistic Krayton rubber "skin"
over 100 gears and 14 motors w/ force feedback sensors
advanced artificial intelligence
tilt and ground sensors so Pleo will know of he falls (or is knocked over)
speakers in both the front and rear
he even comes with a "training leaf"
Technical Specifications:
CPU, Main: 32-bit Atmel AT91SAMS256 ARM7
Memory, Main: 64k RAM, 256k program Flash & 4MB storage Flash
CPU, Camera & Audio: 32- bit Philips NXP RISC ARM7 LPC2103F
Memory, Camera & Audio: w/ 8k RAM & 32k Flash
CPU, Motor Control: (four) 8-bit Toshiba TMP86FH47AUG
Power Supply: 7.2v rechargeable NiMH battery pack
(comprised of six 1.2v 2200mAH AA NiMH cells
black - ground, red = +7.2v, white = internal thermistor)
Dimensions: 7½" high x 6" wide x 20½" long
Weight: 3.5 lbs
Funderar på att lägga upp delar på Ebay, kan det vara rätt?
Så jag tänkte lägga upp lite bilder alltefter som jag obducerar (skruvar isär)!
Här är lite data:
Features:
Weight: 3.5 lbs
