Nån som testat Elektors PCB-kontroll-service
Postat: 2 november 2012, 21:34:33
av TomasL
Check Your PCB Design Online Before Ordering
Are you one of those electronics enthusiasts that every once in a while designs a PCB and then sends it off to a PCB manufacturing house to get it done? Then you must be familiar with that nagging feeling of uncertainty about the correctness of your production files. All may look well in the PCB design software but did you check the gerber files...
http://www.elektor.com/news/check-your- ... at=elektor
http://www.pcbvisualizer.com/index.aspx ... sh&alise=0
Re: Nån som testat Elektors PCB-kontroll-service
Postat: 3 november 2012, 10:58:02
av prototypen
Nej.
Behöver inte då mitt program "ritar" precis som det blir och DRC design rule check(kollar isolationsavstånd och rena kortslutningar) också finns i programmet.
Protte
