Är det här nått att ha???
Postat: 15 november 2003, 02:14:26
av Jonaz
Programmerare STAG PP39 inklusive EPROM & EEPROM-modul 39M100,
Mikroprocessor-modul 39M200, engelskspråkig manual, nätkabel, seriekabel
och PC-programvara för DOS. Utrustningen testad och i utmärkt skick!
* EPROM & EEPROM-modul 39M100 stöder:
EPROM: 2716 tom 27512
CMOS-EPROM: 27C32 tom 27C512.
EEPROM: 2816 tom 28256
CMOS-EEPROM: 28C16 tom 28C256.
* Mikroprocessor-modulen 39M200 stöder mikrokontrollerkretsar :
Intels 8741, 8742, 8748, 8749, 8751, 8752, 8755 inkl kompatibla fabrikat
Motorolas 68701 och 68705.
Kommunicerar med PC via serieport RS232C med hjälp av medföljande DOS-programvara :
Stagcom 1 ver 8.60 - Memory DOS
* Full screen editing is available, displaying 256 bytes of data at one time.
* Data is shown and editable in hexadecimal and ASCII simultaneously.
* Files can be imported from disk, edited and re-exported with a minimum of effort.
* A graphical display is provided for gang and set programming (where applicable)
showing the device & configurations in 8,16 or 32-bit modes.
* A device serialization feature is included which allows a unique security number
to be programmed into unused memory of a device.
StagCom 1 increments this number each time a device is programmed.
* Connection to the programmer is via its fast serial port, supporting all popular I/0 formats.
* Device parameters such as manufacturer, device type, start/stop addresses, etc.
can be set by the user and saved to disk for immediate recall at a later date.
* In addition, operation error statistics are recorded to provide a qualitative analysis
of the programmed silicon devices.
Jonaz
Postat: 16 november 2003, 00:48:42
av henkebenke
En eprom/eeprom programmerare är väl aldrig fel? Däremot känns processorerna lite out-of-date.
Postat: 17 november 2003, 17:54:56
av Robert Nielsen
priset är väl lite väl dyrt????
Såg också annonsen på tradera...
Postat: 17 november 2003, 18:01:32
av Jonaz
ja det är det nog. men jag hoppar över den.
