Sqrt på Cortex-M3
Postat: 10 juli 2011, 16:15:35
Godagens!
Jag slåss fortfarande med att få floats att fungera 100%.
När jag gör en sqrtf så får jag errorn nedan och jag har ingen aning om hur jag ska fixa detta.
Samma sak händer med andra funktioner.
Men multiplikation och division fungerar.
Min Makefil:
Hat någon en ide?Compiling...
/usr/local/CodeSourcery/bin/arm-none-eabi-gcc -mcpu=cortex-m3 -mthumb --no-builtin-memcpy --no-builtin-memset -std=gnu99 -O1 -g -c ./source/startup.c ./source/system_LPC17xx.c ./source/main.c ./source/misc.c ./source/leds.c ./source/timer.c ./source/uart.c ./source/pwm.c ./source/gps.c ./source/i2c.c ./source/itg3200.c ./source/bma180.c
Done!
Linking...
/usr/local/CodeSourcery/bin/arm-none-eabi-gcc -mcpu=cortex-m3 -mthumb --no-builtin-memcpy --no-builtin-memset -T link.T -Wl,--build-id=none startup.o system_LPC17xx.o main.o misc.o leds.o timer.o uart.o pwm.o gps.o i2c.o itg3200.o bma180.o -o main.elf
main.o: In function `main':
/media/FCB7-6FF5/Quadrocopter/Koder/Quad_code/./source/main.c:33: undefined reference to `sqrtf'
collect2: ld returned 1 exit status
make: *** [main.elf] Error 1
Min Makefil:
CC = /usr/local/CodeSourcery/bin/arm-none-eabi-gcc
COMMON = -mcpu=cortex-m3 -mthumb --no-builtin-memcpy --no-builtin-memset
CFLAGS = $(COMMON) -std=gnu99 -O1 -g
LDFLAGS = $(COMMON) -T link.T -Wl,--build-id=none
DIR = ./source/
SRCC = $(DIR)startup.c $(DIR)system_LPC17xx.c $(DIR)main.c $(DIR)misc.c $(DIR)leds.c
SRCC += $(DIR)timer.c $(DIR)uart.c $(DIR)pwm.c $(DIR)gps.c $(DIR)i2c.c $(DIR)itg3200.c
SRCC += $(DIR)bma180.c
SRCO = startup.o system_LPC17xx.o main.o misc.o leds.o timer.o uart.o pwm.o gps.o i2c.o
SRCO += itg3200.o bma180.o
all: clean main.elf
main.o: $(SRC)
@echo "Compiling..."
$(CC) $(CFLAGS) -c $(SRCC)
@echo "Done!"
main.elf: main.o
@echo "Linking..."
$(CC) $(LDFLAGS) $(SRCO) -o main.elf
@echo "Done!"
clean:
@echo "Cleaning..."
rm -f *.o *.elf
