Optimist? (förslag på nytt stegmotordrivkort på CNC-zone)
Postat: 7 mars 2007, 21:25:00
Any interest in a bipolar micro-step 5 Amp/phase 48 volts (maximum), 4 Axis board?
Specs:
Micro-step mode:
Full, half, 1/4, 1/8, 1/5, 1/10 and 1/16
Automatic maximum torque feature (peak to RMS compensation) depending on stepping mode and speed.
Micro-step reference waveform "morphing" depending on speed.
Independent screw terminal outputs for unused PC parallel port pins.
Charge pump (software monitoring feature) on board (for Mach3).
Over-Current, over-temperature and over-voltage protection per axis.
Opto isolated Step /Direction and Enable signals.
Target introductory prices:
Kit: $140.00
Assembled and tested: $180.00
http://www.cnczone.com/forums/showthread.php?t=33756
Det är alltså bara på designstadiet men om det byggs till detta priset så är det ju en given succe!
Specs:
Micro-step mode:
Kit: $140.00
