Nybörjarfråga angånde Assembler (PIC)
Postat: 15 december 2006, 09:30:58
Jag håller på att läsa lite om assembler programmering,
men jag har stött på en litet problem..
Jag förstår inte vart dom har fått siffran 5 ifrån i följande kommando, (BSF 03h,5)
se exemple nedan....
We are going to give you some example code on what we have just learnt. Dont try and compile this yet, we will do that when we come to our first program. We are just trying to show how the above is actually programmed and introduce a couple of instructions along the way. We are going to set up Port A as per the example above.
First, we need to switch from Bank 0 to Bank 1. We do this by setting the STATUS register, which is at address 03h, bit 5 to 1.
BSF 03h,5
The BSF Means Bit Set F. The letter F means that we are going to use a memory location, or register. We are using two numbers after this instruction 03h, which is the STATUS register address, and the number 5 which corresponds to the bit number. So, what we are saying is Set bit 5 in address 03h to 1.
We are now in Bank 1.
http://www.hobbyprojects.com/pic_tutori ... rial2.html
BSF 03h,5
