Kan denna vara nått att ha? FPGA!
Postat: 14 oktober 2006, 21:21:34
FTDI & Altera ACEX Module:
http://www.lawicel-shop.se/shop/custom/ ... &refcode=p
Vad kan man använda en sån liten FPGA till?
Billig e den, Exkl moms: 799,00 sek
Beskrivning: Morph-IC combines the flexibility of FTDI's FT2232C USB interface IC together with an Altera ACEX 1K series FPGA (EP1K10TC100-3) in a compact ready to use module. The power and IO pins of the module are brought out onto 2 x 20-pin, 0.1in pitch headers on the underside of the PCB, allowing easy connection to the pins on a 0.1in grid. The module can also be plugged into a PCB using readily available mating PCB connectors (two included). Included on the module are the 3.3V and 2.5V voltage regulators required by the FPGA as well as a 50MHz CMOS oscillator hard wired to one of its two clock pins. Power control to meet USB suspend current requirements is provided by the FT2232C and an on board MOSFET power switch.
/Tripp
/Tripp
