Arduino kod fråga
Postat: 28 juni 2022, 15:36:33
Håller på med ett projekt där jag tänkt använda mig av Wesley Kagans freevalve kod.
Den är dock för 4takt och jag kan inte förstå var detta defineras? Jag vill ha 2takt, 0-360 grader = en cykel.
Tack på förhand
Tack på förhand
//This code is full of test strings and is generally a conglomerate of code from stackexchange and
//bad form. If it looks stupid, I probably wrote it.
//Wesley Kagan, 2020
const int hall = 2;
int hallcounter = 0;
int hallstate = 0;
int lasthallstate = 0;
unsigned long triggerTime;
unsigned long last_triggerTime;
unsigned long timeGap;
unsigned long last_timeGap;
unsigned int degree;
unsigned int state;
int newstate;
void setup() {
pinMode(hall, INPUT);
Serial.begin(115200);
pinMode(13, OUTPUT); // sets the digital pin 13 as output
pinMode(12, OUTPUT); // sets the digital pin 12 as output
attachInterrupt(0, magnet_detect, RISING);//Initialize the intterrupt pin digital pin 2
degree = 0;
void loop()
//The compiler says this is needed otherwise the govt. takes my cat
void magnet_detect() {
hallcounter ++;
triggerTime = millis();
timeGap = triggerTime - last_triggerTime;
last_triggerTime = triggerTime;
if (timeGap >= last_timeGap + last_timeGap / 2)
//Serial.println(state);
Serial.println("missing tooth");
hallcounter = 1;
state++; //This right here is garbage and you know it.
last_timeGap = timeGap;
//Serial.println(hallcounter);
degree = hallcounter * 6;
if ((state % 2) == 0) { //Bool wasn't working so this dumpster fire got started.
Serial.print("STATE 1 ");
Serial.println(degree);
if (6 <= degree && degree <= 180) { //EDIT HERE INTAKE
digitalWrite(13, HIGH); // sets the digital pin 13 on
else {
digitalWrite(13, LOW); // sets the digital pin 13 off
if ((state % 2) == 1) {
Serial.print("STATE 2 ");
if (180 <= degree && degree <= 354) { //EDIT HERE EXHAUST
digitalWrite(12, HIGH); // sets the digital pin 13 on
else {
digitalWrite(12, LOW); // sets the digital pin 13 off
lasthallstate = hallstate;
