Här är koden om någon vill göra en likadan.
Jag har inte inluderat ordlistan då jag är osäker på copyright av SAOL.
// Print 4-letter word on a DL2416T
// Coded by Mikael Karlsson 2022-01-16
// Requires the https://github.com/ontuo/DL2416-Arduino-library
// I did modified it to suit my needs, hence why it's included in the code
//#include <DL2416T.h>
// Define all pins here
int D0 = 12; // Data bit 0 = 11 on display
int D1 = 2; // Data bit 1 = 12 on display
int D2 = 3; // Data bit 2 = 13 on display
int D3 = 4; // Data bit 3 = 14 on display
int D4 = 5; // Data bit 4 = 17 on display
int D5 = 6; // Data bit 5 = 16 on display
int D6 = 7; // Data bit 5 = 15 on display
int BL = 8; // = 18 on display
int AD0 = 9; // A0 = 9 on display
int AD1 = 10; // A1 = 7 on display
int CE1 = 11; // CE1 = 1 on display, tie #2 to ground (pin 2)
int CLR = 13; // CLR = 3 on display
int WR = 14; // WR = 6 on display
// All words that I could find in Swedish without extended characters
// NOTE TO MYSELF, NEEDS TO BE UPPER CASE!!!!!!!!!! (don't ask me why I have this note here)
static const char fourletterwords[] PROGMEM = {"ABERACNE..."};
int randomnumber; // holds the random number
char myLetter; // holds a character
// Setup routine
void setup() {
// Initialize all pins, modified library
DL2416Tinit(D0, D1, D2, D3, D4, D5, D6, AD0, AD1, WR, CE1, CLR, BL);
randomSeed(analogRead(A4)); // Get a random value seed from an empty analog port
// And loop away
void loop() {
// 8488 characters divided by 4 = 2122 words, so 2121 is the largest random number we can have
randomnumber = random(0,2121); // Get a random number between 0 and 2121 (return is float)
int wordindex = (int) randomnumber * 4; // Multiply the randowm word by 4 so we get to the right place in PROGMEM
int position = 3; // the position of the character, display is backward, 3 is rightmost character
for (byte i = 0; i < 4; i++) // Loop 4 times to get 4 characters
myLetter = pgm_read_byte_near(fourletterwords + (i + wordindex) ); // Read a character from PROGMEM
DL2416TsetLetter(myLetter, position); // Display it
position --; // Count down to 0, display is from right to left, 3 to 0
delay(4000); // Wait some time
// TODO:
// Add RTC and code for it
// set position in display, rightmost = 3 leftmost = 0
void setAdress(int position)
Serial.print("position: ");
Serial.print(position);
Serial.print("\n");
digitalWrite(AD1, (position & 0b10) >> 1);
digitalWrite(AD0, (position & 0b01) >> 0);
//will output the letter in the determined position
void DL2416TsetLetter(char letter, int position)
Serial.print("setletter: ");
Serial.print(letter);
Serial.print("\n");
setAdress(position);
digitalWrite(WR, 0);
digitalWrite(D6, (letter & 0b1000000) >> 6);
digitalWrite(D5, (letter & 0b0100000) >> 5);
digitalWrite(D4, (letter & 0b0010000) >> 4);
digitalWrite(D3, (letter & 0b0001000) >> 3);
digitalWrite(D2, (letter & 0b0000100) >> 2);
digitalWrite(D1, (letter & 0b0000010) >> 1);
digitalWrite(D0, (letter & 0b0000001) >> 0);
digitalWrite(WR, 1);
void DL2416Tclear()
digitalWrite(CLR, 0);
//according to datasheet we need at least 1 sec to clear
delay(1000);
digitalWrite(CLR, 1);
//turnOff will not delete anything, only dim the display
void DL2416TOff()
digitalWrite(BL, 0);
void DL2416TturnOn()
digitalWrite(BL, 1);
void DL2416TPrint(String word)
int len = 0;
if (word.length() > 4)
len = 4;
else
len = word.length();
for (int i = 0; i < len; i++)
int m = len - 1 - i;
DL2416TsetLetter(word[i], m);
void DL2416Tinit(uint8_t D0, uint8_t D1, uint8_t D2, uint8_t D3, uint8_t D4, uint8_t D5, uint8_t D6, uint8_t AD0, uint8_t AD1, uint8_t WR, uint8_t CE1, uint8_t CLR, uint8_t BL)
// Set pins as outputs
pinMode(D0, OUTPUT);
pinMode(D1, OUTPUT);
pinMode(D2, OUTPUT);
pinMode(D3, OUTPUT);
pinMode(D4, OUTPUT);
pinMode(D5, OUTPUT);
pinMode(D6, OUTPUT);
pinMode(WR, OUTPUT);
pinMode(CLR, OUTPUT);
pinMode(CE1, OUTPUT);
pinMode(BL, OUTPUT);
pinMode(AD0, OUTPUT);
pinMode(AD1, OUTPUT);
digitalWrite(WR, HIGH);
digitalWrite(AD0, HIGH);
digitalWrite(AD1, HIGH);
digitalWrite(BL, HIGH);
digitalWrite(CLR, HIGH);
digitalWrite(CE1, LOW);
