Projekt Labbagg
peter555
Inlägg av peter555 »
Läs SMPS länken igen, speciellt det här:
Radio frequency interference — The current in a SMPS is switched on and off sharply, and contains high frequency spectral components. Long wires between the components may reduce the high frequency filter efficiency provided by the capacitors at the inlet and outlet. This high-frequency current can generate undesirable electromagnetic interference. EMI filters and RF shielding are needed to reduce the disruptive interference. Linear PSUs generally do not produce interference, and are used to supply power where radio interference must not occur.
Electronic noise at the output terminals — Inexpensive linear PSUs with poor regulation may experience a small AC voltage "riding on" the DC output at twice mains frequency (100/120 Hz). These "ripples" are usually on the order of millivolts, and can be suppressed with larger filter capacitors or better voltage regulators. This small AC voltage can cause problems or interference in some circuits; for example, analog security cameras powered by switching power supplies may have unexpected brightness ripples or other banded distortions in the video they produce. Quality linear PSUs will suppress ripples much better. SMPS usually do not exhibit ripple at the power-line frequency, but do have generally noisier outputs than linear PSUs. The noise is usually correlated with the SMPS switching frequency.
Acoustic noise — Linear PSUs typically give off a faint, low frequency hum at mains frequency, but this is seldom audible (vibration of windings in the transformer is responsible). SMPSs, with their much higher operating frequencies, are not usually audible to humans (unless they have a fan, in the case of most computer SMPSs). A malfunctioning SMPS may generate high-pitched sounds, since they do in fact generate acoustic noise at the oscillator frequency.
ElectricMan
Skype: ElectricManSwe
Inlägg av ElectricMan »
Det står ju att det var bara några milivolt?
Men kommer amperemetern att hoppa?
peter555
Det står att det är mV i linjära aggregat, får du till ett switchat med samma prestanda så är du duktig.
Andy
Inlägg av Andy »
Jag ser ingen direkt anledning till oro för vare sig strömbegränsning eller högfrekvens störningar, ett filter på utgången fixar störningarna och strömbegränsning fungerar som på andra agg. Vad som eventuellt kan vara svårt att driva med switchat kan vara radiostationer men bara om man inte filtrerar bort det mesta av skiten som alstras. Många kommersiella labb aggregat är ju switchade nu för tiden och fungerar alldeles utmärkt. Jag har själv ett PSP-405 som jag är ganska nöjd med (om man bortser från fläktljudet)! :?
ElectricMan
Vad är det för filter jag ska köpa då ?
Andy
Inlägg av Andy »
Har du studerat databladen för styrkretsen?
ElectricMan
Nee det är ju en köpt biltema grej!
peter555
Andy:
Det där aggregatet har jag själv kört med, jag vet inte vad det kostar men jag antar att det inte är gratis. Det är mycket troligt att de har en linjär postregulator på det för att undvika problemen med switchade aggregat. Du lär inte komma i närheten av dess prestanda med biltemas simpla aggregat. Det är inte heller så lätt att fixa varabel strömbegränsning på ett direktswitchat aggregat, vissa styrkretsar klarar det inom ganska små områden.
Håller helt med om att fläkten på det är helt avskyvärd.
Andy
Inlägg av Andy »
Vad står det på ryggen på chippet (den lilla svarta saken med 8 ben på) som sitter på kretskortet?
Andy
Inlägg av Andy »
Peter555; vi skrev nog samtidigt,
Det beror lite på vilket chip som styr det hela om det går att göra en vettig strömbegränsning eller inte.
Fläkten startar visserligen inte under ca 2A men den stoppar o startar i ett! :?
ElectricMan
det står KA34063A VF31A
Dvs den här kretsen. :)
edit: Det gick inte så bra att direktlänka. Klicka på knappen "If you want to view datasheet, Click To Here!!"
(Konstig engelska..) :D
ElectricMan
Är det bra eller dåligt :?:
för...?
ElectricMan
