Sida 2 av 2
Re: Klipper ender 3 Raspberry pi.
Postat: 7 augusti 2025, 21:52:18
av MNorrgren
Här är hela min kod, skratta inte, en del är fle, mycket ska fixas....
# This file contains common pin mappings for the BIGTREETECH Kraken.
# To use this config, the firmware should be compiled for the
# STM32H723 with a "128KiB bootloader" "25 MHz crystal"
# and "USB (on PA11/PA12)" or "CAN bus (on PD0/PD1)".
# See docs/Config_Reference.md for a description of parameters.
[include mainsail.cfg]
[include timelapse.cfg]
[include Exclude_Object.cfg]
[include Speed.cfg]
[display_status]
[exclude_object]
[pause_resume]
[include macros.cfg]
[include RGB_LEDs.cfg]
[include fans.cfg]
#[include part-cooling.cfg]
##### VzBoT############
[printer]
kinematics: corexy
max_velocity: 1000
max_accel: 5000
#max_accel_to_decel: 0.5
max_z_velocity: 20
max_z_accel:500
square_corner_velocity: 10
# Kraken motherboard
[mcu]
serial: /dev/serial/by-id/usb-Klipper_stm32h723xx_250015001351313338343730-if00  # put your own Serial here.
#restart_method: command
#   X axis
# X
[stepper_x]
step_pin: PC14
dir_pin: PC13
enable_pin: !PE6
rotation_distance: 40
microsteps: 16
full_steps_per_rotation: 200
endstop_pin: PF0       #make sure to set the correct pin here.
#homing_positive_dir: false
position_endstop: 0
position_min: 0
position_max: 270
homing_speed: 30
second_homing_speed: 2.5
homing_retract_dist: 5.0
# X1
[stepper_x1]
step_pin: PE5
dir_pin: PE4
enable_pin: !PE3
microsteps: 16
#   Y Axis
# Y
[stepper_y]
step_pin: PE2
dir_pin: PE1
enable_pin: !PE0
microsteps: 16
endstop_pin: PC15        #make sure to set the correct pin here.
position_endstop: 0
position_min: 0
position_max: 290
homing_speed: 30
# Y1
[stepper_y1]
step_pin: PB9
dir_pin: PB8
enable_pin: !PB7
microsteps: 16
#   Z axis
# Z
[stepper_z]
step_pin: PG9
dir_pin: PG10
enable_pin: !PG13
microsteps: 16
rotation_distance: 8
endstop_pin: PF1               #make sure to set the correct pin here.
position_endstop: 0
position_max: 330
homing_speed: 5.0
# Z1
[stepper_z1]
step_pin: PG11
dir_pin: PD7
enable_pin: !PG12
microsteps: 16
endstop_pin: PF2               #make sure to set the correct pin here.
# Extruder
[extruder]
step_pin: PB4
dir_pin: PB3
enable_pin: !PB5
microsteps: 32
rotation_distance: 4.660444672
nozzle_diameter: 0.400
filament_diameter: 1.750
heater_pin: PF6 # HE0
max_extrude_only_distance: 1000.0
max_extrude_cross_section: 500
max_extrude_only_velocity: 200
max_extrude_only_accel: 10000
min_extrude_temp: 200
pressure_advance: 0.02
pressure_advance_smooth_time: 0.03
#Thermistor PT1000
sensor_type: PT1000
sensor_pin:  PB1 # T0
#control: pid
#pid_Kp: 22.2
#pid_Ki: 1.08
#pid_Kd: 114
min_temp: 0
max_temp: 450
# PT100
#sensor_type:MAX31865
 # sensor_pin: PC9
#spi_bus: spi3a
#rtd_nominal_r: 100
#rtd_reference_r: 430
#rtd_num_of_wires: 3
#control: pid
#pid_Kp: 22.2
#pid_Ki: 1.08
#pid_Kd: 114
#min_temp: 0
#max_temp: 450
#   Heating and humidity
[temperature_sensor Chamber]
sensor_type: BME280
i2c_address: 118
i2c_mcu: mcu
i2c_bus: i2c2_PB10_PB11
[temperature_sensor Cabinett]
sensor_type: ATC Semitec 104GT-2
sensor_pin: PC5
min_temp: 0
max_temp: 100
gcode_id: C
[temperature_sensor Coolant]
sensor_pin: PC4
min_temp: 0
max_temp: 100
gcode_id: D
[temperature_sensor KRAKEN]
sensor_type: temperature_mcu
[temperature_sensor raspberry_pi]
sensor_type: temperature_host
min_temp: 10
max_temp: 100
[heater_bed]
heater_pin: PF5
sensor_pin: PB0 # TB
#control: watermark
min_temp: 0
max_temp: 130
#   FANS
#[fan_generic Waterfan]
#pin: PA1
#[fan_generic Waterpump]
#pin: PA0
#[fan_generic CPAP]
#pin: PA2
#[fan_generic Housing]
#pin: PA4
#[fan_generic fan4]
#pin: PA3
#[fan_generic fan5]
#pin: PA5
#[fan_generic fan6]
#pin: PA6
#tachometer_pin: PC1
#[fan_generic fan7]
#pin: PE8
#tachometer_pin: PG0
#   Filament switch
[filament_switch_sensor material_0]
switch_pin: PF3
# TMC2160 configuration
[tmc5160 stepper_x]
cs_pin: PD6
spi_software_sclk_pin: PC6
spi_software_mosi_pin: PC8
spi_software_miso_pin: PC7
#diag1_pin: PC15
run_current: 2.800
sense_resistor: 0.022
stealthchop_threshold: 50
interpolate: true  #false
[tmc5160 stepper_x1]
cs_pin: PD5
#diag1_pin: PC15
run_current: 2.800
[tmc5160 stepper_y]
cs_pin: PD4
#diag1_pin: PF0
run_current: 2.800
[tmc5160 stepper_y1]
cs_pin: PD3
#diag1_pin: PF0
run_current: 2.800
[tmc5160 stepper_z]
cs_pin: PD2
#diag1_pin: PF1
run_current: 1.2
sense_resistor: 0.075
[tmc5160 stepper_z1]
cs_pin: PA15
#diag1_pin: PF1
run_current: 1.2
[tmc5160 extruder]
cs_pin: PA9
#diag1_pin: PF1
interpolate: true
run_current: 0.85 #run_current: 1.2
hold_current: 0.100
stealthchop_threshold: 0 #stealthchop_threshold: 999999
#driver_TBL: 0
#driver_HEND: 6
#driver_HSTRT: 7
#driver_TOFF: 4
#   Extra
[idle_timeout]
timeout: 1800
gcode =
  {% if printer.pause_resume.is_paused %}
    M104 S0
  {% else %}
    TURN_OFF_HEATERS
    #M84
  {% endif %}
[board_pins]
aliases:
    # FPC header, Aliases EXP1 & EXP2 for mini12864
    EXP1_1=PG5, EXP1_2=PG4,
    EXP1_3=PG3, EXP1_4=PG2,
    EXP1_5=PD15, EXP1_6=PD14,
    EXP1_7=PD13, EXP1_8=PD12,
    EXP1_9=<GND>, EXP1_10=<5V>,
    # EXP2 header
    EXP2_1=PE13, EXP2_2=PE12,
    EXP2_3=PG8, EXP2_4=PE11,
    EXP2_5=PG7, EXP2_6=PE14,
    EXP2_7=PG6, EXP2_8=<RST>,
    EXP2_9=<GND>, EXP2_10=<NC>
# INPUT SHAPER############################################
#[include sample-bigtreetech-lis2dw-v1.0.cfg]
[input_shaper]
#shaper_type_x = mzv
#shaper_freq_x = 0
#shaper_type_y = mzv
#shaper_freq_y = 0
# See the sample-lcd.cfg file for definitions of common LCD displays.
#[bltouch]
#sensor_pin: ^PG1
#control_pin: PE9
# Proximity switch
#[probe]
#pin: PD11
#[output_pin ps_on_pin]
#pin: PD10
#[neopixel my_neopixel_1]
#pin: PF12
#[neopixel my_neopixel_2]
#pin: PF11
#[hall_filament_width_sensor]
#adc1: PC2
#adc2: PC3
#[adxl345]
#cs_pin: PE10
#spi_bus: spi4
#[servo servo_motor]
#pin: PE7
#i2c_bus:i2c2_PB10_PB11
#*# <---------------------- SAVE_CONFIG ---------------------->
#*# DO NOT EDIT THIS BLOCK OR BELOW. The contents are auto-generated.
#*# [extruder]
#*# control = pid
#*# pid_kp = 39.213
#*# pid_ki = 7.262
#*# pid_kd = 52.938
#*# [input_shaper]
#*# shaper_type_x = mzv
#*# shaper_freq_x = 91.8
#*# shaper_type_y = mzv
#*# shaper_freq_y = 65.6
#*# [heater_bed]
#*# control = pid
#*# pid_kp = 75.656
#*# pid_ki = 1.109
#*# pid_kd = 1290.882
Postat: 7 augusti 2025, 22:25:00
av MNorrgren
Kolla denna guiden och se så du fått med alla steg…
https://athemis.me/projects/klipper_guide/
Postat: 7 augusti 2025, 23:49:37
av l2t
Det började faktiskt funka fungera nu, vet inte riktigt varför men i alla fall.
Mycket återstår att configurera, får nog anledning att återkomma om det :D
Postat: 8 augusti 2025, 00:02:40
av MNorrgren
Men så bra. Det är inte helt enkelt med klipper. Det ser och låter enkelt, men när man ska få ihop allt… nja, inte så enkelt direkt. Vet inte hur många timmar det gått åt…. Men snyggt, härligt du får ihop det! Klipper är fånigt känsligt, jag hade ett mellanslag för mycket på ett ställe… det ställde till det totalt!!
Postat: 11 augusti 2025, 09:05:46
av l2t
Första justering med pressure_advance, hörnen ser faktiskt ganska ok ut.
Postat: 11 augusti 2025, 17:31:28
av MNorrgren
Vad justerade du det till? Ser ju fint ut!!
Postat: 11 augusti 2025, 19:19:12
av l2t
Kom på att det är kanske inget bra exempel, kommer ju inte upp i någon hastighet på den kuben men i alla fall.
med direkt extruder så hamnade jag på ca 0.04 i pressure advance.
Går nog att finjustera lite till.
