Aktuellt datum och tid: 22.21 2010-07-29
Alla tidsangivelser är UTC + 1 timme
Svara på tråd  [ 11 inlägg ]
Författare Meddelande
 Inläggsrubrik: Inventering alla chips på ett pc-moderkort..
InläggPostat: 19.06 2008-12-20
Någon lödde bort varenda chip på ett moderkort och kollade upp var det var för komponenter:
http://www.youritronics.com/tag/computer/
* LF-H80P - 1:1 ethernet transformer
* TEA5767 - single chip FM radio
* RTM660 - 109R Realtek soundcard
* ALC655 - six channel AC’97 audio codec
* CMI9738 - four channel AC’97 audio codec
* RTL8100CL - single-chip fast ethernet controller with power management
* W83627HF-AW - Winbond I/O familly chip
* W49V002FAP - Winbond 256k x 8 cmos flash memory with fwh interface
* Samsung 610 K9K8G08U0M - 1G x 8 Bit / 2G x 8 Bit NAND Flash Memory - Samsung semiconductor
* Samsung 616 K9WAG08U1A - 1G x 8 Bit / 2G x 8 Bit NAND Flash Memory - Samsung semiconductor
* SST39VF04 - 5124K x 8 CMOS Multi-Purpose Flash
* ATJ2085W - single-chip for flash-based digital music player
* ATJ2085H - single-chip for flash-based digital music player
* APL1087 - 800mA Low Dropout Fast Response Positive Adjustable Regulator and Fixed 1.8V, 2.5V and 3.3V
* GD75232 - multiple RS232 drivers and receivers - Texas Instruments
* TPS2210A - PC Card Power-Interface Switch w/ Reset For Serial PCMCIA Controller - Texas Instruments
* TPS5130 - triple synchronous buck controller with nmos ldo controller - Texas Instruments
* MAX1909E - Multichemistry Battery Charger with Automatic System Power Selector
* ISL6559CR - Multi-Phase PWM Controller
* 7407 - Hex Buffers/Drivers With Open-Collector High-Voltage Outputs - Texas Instruments
* IRF3704S - SMPS MOSFET - International Rectifier
* F3711S - HEXFET Power MOSFET - International Rectifier
* CEB6030L - N-Channel Logic Level Enhancement Mode Field Effect Transistor - Chino-Excel Technology
* FDD8896 - 30V N-Channel PowerTrench® MOSFET - Fairchild semiconductor
* FDD8880 - N-Channel PowerTrench® MOSFET 30V, 58A, 9mO - - Fairchild semiconductor
* 20N03L - Power MOSFET - ON Semiconductor
* PMBS3904 - equivalent 2N3904 NPN Epitaxial Silicon Transistor
* LM324M - Low Power Quad Operational Amplifiers - National Semiconductor
* ISL6227CA - Dual Mobile-Friendly PWM Controller with DDR Option - Intersil Corporation
* G1421 - 2W Stereo Audio Amplifier with No Headphone Coupling Capacitor Function - Global Mixed-mode Technology Inc
* G792 - probably fan controller - Global Mixed-mode Technology Inc
* 74LVC08A - quadruple 2-input positive-and gates
* 74AHCT125 - quadruple bus buffer gates with 3-state outputs
* 74AHCT08D - quadruple 2-input positive-and gates
* AO4407L - P-Channel Enhancement Mode Field Effect Transistor - Alpha & Omega Semiconductors
* AO4800BL - Dual N-Channel Enhancement Mode Field Effect Transistor - Alpha & Omega Semiconductors
* ISL6207CB - High Voltage Synchronous Rectified Buck MOSFET Driver - Intersil Corporation
* LVC14A - Hex inverting Schmitt-trigger with 5V tolerant input - NXP Semiconductors
* 74LCX00 - Low Voltage Quad 2-Input NAND Gate with 5V Tolerant Inputs
* APL5331 - 3A Bus Termination Regulator - Anpec Electronics Coropration
* 4431B - P-Channel 30-V (D-S) MOSFET - Vishay Siliconix
* 2951 - adjustable micropower voltage regulators - National Semiconductor
* RT9173 - 1.5A/3A Bus Termination Regulator - Richtek Technology Corporation
* AT93C46 - 3-Wire Serial EEPROMs - ATMEL Corporation
* 4422 - N-Channel Enhancement Mode Field Effect Transistor - Alpha & Omega Semiconductors
* 74HCT14 - hex schmitt-trigger inverters - Texas Instruments
* 74F32D - quadruple 2-input positive-or gates - Texas Instruments
* CV137PAG - Programmable FlexPC Clock for AMD K8 Processor ATI RS480 - Integrated Device Technology
* 10 KOhm thermistor
* SMD inductors - 15uH, 4,7uH, 6,8uH, 3,3uH
* SMD crystal oscillators and connectors
Verkar som moderkortet använder sig av buck regulatorer uteslutande.
(Finns en byggbeskrivning på Asus Eee PC bil laddare också på sidan :) )
Upp
 Profil
 Inläggsrubrik:
InläggPostat: 20.12 2008-12-20
Haha, någon har haft rolig verkar det som. Måste ta en bra stund att få bort alla komponenter :D
Upp
 Profil
 Inläggsrubrik:
InläggPostat: 20.25 2008-12-20
Med ett strykjärn eller varmluftspistol går det lätt som en dans!! :)
Upp
 Profil
 Inläggsrubrik:
InläggPostat: 20.45 2008-12-20
Hur pass tåliga är komponenterna för dom metoderna?, måste vara lätt att fritera ett chip. Kisel börjar förstöras vid 150 °C.
Upp
 Profil
 Inläggsrubrik:
InläggPostat: 20.55 2008-12-20
Blueint, hur tror du att de har kommit DIT?
Genom en varmluftsugn med minst 230 grader.(jodå det finns andra metoder också)
Dessutom friteras de inte, det är "popcorning" som är problemet.
Protte
Upp
 Profil
 Inläggsrubrik:
InläggPostat: 21.08 2008-12-20
Klart det går att värma loss, det kritiska är handlaget. Dvs göra det snabbt nog utan att lossa pcb banorna.
Upp
 Profil
 Inläggsrubrik:
InläggPostat: 21.17 2008-12-20
Jag va bara tvungen att testa med ett strykjärn. Och det gick förvånansvärt lätt :D
Upp
 Profil
 Inläggsrubrik:
InläggPostat: 04.42 2008-12-21
"Någon lödde bort varenda chip på ett moderkort och kollade upp var det var för komponenter"
Var får en del människor all tid ifrån? :D
Kul läsning. Ganska vanliga komponenter. Det är väl egentligen bara "W83627HF-AW - Winbond I/O familly chip" som inte direkt ligger i var mans sortimentskåp.
_________________
"Läsning avleder efter någon tid vår tanke alltför mycket från dess skapande uppgift.
Varje människa som läser för mycket använder sin egen hjärna för lite och förfaller till lata tankevanor."
-Einstein
Upp
 Profil Skicka e-post
 Inläggsrubrik:
InläggPostat: 11.44 2008-12-21
Hehe...
_________________
it's a chick, she is nearly naked, what can you ask for more?
Jag är känd på internet
Upp
 Inläggsrubrik:
InläggPostat: 14.47 2008-12-21
TEA5767 FM-radio? Varför?
Upp
 Profil
 Inläggsrubrik:
InläggPostat: 18.14 2008-12-21
Njae, det är plasten i komponenterna som börjar förstöras vid 150 grader, inte så mycket chippen faktiskt.
Fast ju varmare det är desto snabbare försämras de ju, men inget akut händer vid just 150 grader.
Upp
 Profil
Visa inlägg nyare än:  Sortera efter
Vilka är online
Användare som besöker denna kategori: Inga registrerade användare och 2 gäster
Du kan inte skapa nya trådar i denna kategori
Du kan inte svara på trådar i denna kategori
Du kan inte redigera dina inlägg i denna kategori
Du kan inte ta bort dina inlägg i denna kategori
Du kan inte bifoga filer i denna kategori
Sök efter:
Hoppa till:
Powered by phpBB © 2000, 2002, 2005, 2007 phpBB Group
Swedish translation by Peetra & phpBB Sweden © 2006-2010
