Flowcine startade 2013 med utgångspunkt för att tillhandahålla utrustning för stabilisering av kameror för filmindustrin. Vi har snabbt nått en världsmarknad med våra mekaniska produkter men det är dax att nu styra upp elektronik sidan.
Vi söker dig som vill sitta som ansvarig för den ny startade elekronik sidan av verksamheten. Viktiga krav är självgående, tillföra egna ideér och ha vara kreativ. Extra extra plus är de som kan allt om linear/brushless/voice coil motorer. Ni kan antingen PMa mig här, maila mig på peter@flowcine.com eller använda den officiella adressen längst ner
Since 2013 Flowcine has been working on improving on the tool set available to professional DOPs, helping them to achieve better looking, more stable shots. Our products have so far been completely mechanical, based on simple physical principles. But we’re currently working on several new products that involves the use of electronics and motorised stabilisation. Now we’re looking for an electrical engineer who can help us push those new products further.
Responsibilities
As our electrical engineer, you’ll be responsible of leading all of our projects involving electronics. You’ll work closely with our algorithm guru and our mechanical engineer, being the bridge between the two.
Qualifications
We think that you probably match most of the statements below. Or at least a few!
Basic control theory
For you, control concepts like filters, controllers and minimizing of a cost function are everyday matters. You don’t have to be able to implement all of it from start, but you need to have a thirst to learn all about it.
Programming (C/C++/Python etc)
Of course you’re in to programming. For you, the language isn’t important. You’ll use the best tool for the job.
Embedded systems
We expect you to have experience in embedded systems and real time applications.
Basic electronics
You probably have been doing electronics in some way. Low pass filters, currency limiting, ESD-protection and serial communication are probably all familiar concepts to you. Vast experience of brushless servo motors is a huge plus.
Basic knowledge in estimation
Implementing math into code
We think you’ll be good at seeing a mathematical solution to a problem and implementing this into executable code.
Ability to work independently
We think it’s important that you enjoy to work quite independently. You will be in charge of the electronic parts of our projects and will be responsible to move them forward.
An interest in cameras and gimbals
If you’re like us, you’re interested in camera technology and gimbals!
Get in touch!
If this sounds like you, please let us know! We'd love to get in touch! Send us a mail at work@flowcine.com, and we'll meet up for a coffee!
